  • Total antal emner: 1414
  • Flest online idag: 14
Forfatter Emne: Talforståelse  (Læst 23348 gange)
Talforståelse
« Dato: 02, Maj 2024 - 19:51 »
Citat fra: politiken.dk
Gymnasielærer er foruroliget over mange elevers talforståelse: »De tror, at to divideret med to er nul«
Måske tror de at Obelus ÷ på deres danske skole-lommeregner virker som devisor istedet for som minus tegn❓
Citat fra: Wikipedia Obelus ÷
This form of the obelus was also occasionally used as a mathematical symbol for subtraction in Northern Europe; such usage continued in some parts of Europe (including Norway and, until fairly recently, Denmark).
Måske har DR-TV en MatematikEkspert, som med velvalgte ord og store armbevæglser kan løse problemet❓😌
**2024-05-07 20;18;52,85 -Redigeret
VurderingsStyrelsen har nuligvis også store problemer med at dele en tidligere stor byggegrund i en nuværende antal mindre byggrunde❓❓❓
Måske er der ingen Obelus eller Solidus (slash) taster til deling/division på deres computerTasteturer❓❓❓ 🙁
2024-05-19  8;55;23,77 Redigeret
Overskriften burde måske hedde Fejlslutning istedet for Talforståelse❓❓❓❓❓
Division kan være særdeles vanskelig:
Citat fra: KidsVorldFun
17 Camels and 3 Sons
Long ago, there lived an old man with his three sons in a deserted village, located in the vicinity of a desert. He had 17 camels, and they were the main source of his income. He used to rent out camels as a means of shipping in the desert. One day, he passed away. He had left a will, leaving his assets for his three sons.
After the funeral and the other obligations were over, the three sons read the will. While their father had divided all the property he had into three equal parts, he had divided the 17 camels in a different way. They were not shared equally among the three as ‘17’ is an odd number and a prime number, which cannot be divided.
The old man had stated that the eldest son will own half of the 17 camels, the middle one will get one third of the 17 camels, and the youngest one will get his share of camels as one ninth!
All of them were stunned to read the will and questioned each other how to divide the 17 camels as mentioned in the will. It is not possible to divide 17 camels and give half of the 17 camels to the eldest one. It is not possible also to divide the camels for the other two sons.
They spent several days thinking of ways to divide the camels as mentioned in the will, but none could find the answer.
They finally took the issue to the wise man in their village. The wise man heard the problem and instantly found a solution. He asked them to bring all the 17 camels to him.
The sons brought the camels to the wise man’s place. The wise man added a camel owned by him and made the total number of camels 18.
Now, he asked the first son to read the will. As per the will, the eldest son got half the camels, which now counted to 18 / 2 = 9 camels! The eldest one got 9 camels as his share.
The remaining camels were 9.
The wise man asked the second son to read the will. He was assigned 1 / 3 of the total camels.
It came to 18 / 3 = 6 camels. The second son got 6 camels as his share.
Total number of camels shared by the elder sons – 9 + 6 = 15 camels.
The third son read out his share of camels: 1 / 9th of the total number of camels – 18 / 9 = 2 camels.
The youngest one got 2 camels as his share.
Totally there were 9 + 6 + 2 camels shared by the brothers, which counted to 17 camels.
Now, the one camel added by the wise man was taken back.
The wise man solved this problem smartly with his intelligence.
2024-06-22 19;49;43,95 Redigeret
Men talforståelse er slet ikke nogen dårlig evne 😎
Som belønning ønskede Skakbrættets opfinde 1 korn på det førse felt og 2 på det næste og 4 på det tredie osv.
ialt 2^64-1 = 18446744073709551615 korn
Hvormange korn skal der til for at en vægt viser 1 gram?
Kender man (antalkorn) pr. gram kan man udregne antal tons korn ialt.
Citat fra: From Wikipedia, the free encyclopedia: Wheat and chessboard problem
On the entire chessboard there would be 2^64 − 1 = 18,446,744,073,709,551,615 grains of wheat, weighing about 1,199,000,000,000 metric tons. This is over 1,600 times the global production of wheat (729 million metric tons in 2014 and 780.8 million tonnes in 2019).
2024-06-26 19;56;29,69 Redigeret
Resultatets nøjagtighed afhænger af heltals regnekraft og beregningsgrundlaget.
1844674407370955161510=111111111111111111111111111111111111111111111111111111111111111₂
18446744073709551615    Windows10 Lommeregner Videnskabelig 64-bit operativsystem, x64-baseret processor  64bit integer.
Citat fra: Humble Pi - A Comedy of Maths Errors
Matematik kan være svært, så det er ikke så underligt, at verden er fuld af eksempler på matematiske fejl. De fleste fejl er ret ligegyldige. Når et ”tilbud” i supermarkedet ikke kan svare sig, fordi stykprisen er bedre eller når en oversætter kommer til at lade det engelske ord billion være det samme som det danske, giver det anledning til et kort grin, men sjældent mere.
2024-06-30 19;45;19,19 Redigiret.
Matematik kunne måske blive mindre upopurlær, hvis der blev undervist i mere brugbar matematik❓❓❓
2024-07-19 20;35;14,35 Redigeret
Tilbage til start:
=2/2=1  (Libreoffice calc)
2÷2=1   (På windows10 lommeregner)
2-2=0          ''
DR-TV har desvære ingen matematik undervisnings programmer i lighed med f.eks.:
Adding and subtracting - KS2 Maths - BBC Bitesize.
2024-08-04 20;17;58,95 Redigeret.
Citat fra: JP Indland 02/08/2024 KL. 11:14
To skolepiger fik hjælp til matematikken: »Det burde ikke være nødvendigt, men det var det«
Det har givet Louise Hanneckes to døtre både bedre karakterer og mere selvtillid i skolen, at de fik privat lektiehjælp.
Læs evt.: Matematik for millioner af Lancelot Hogben, hvis du har problemer med at forstå danske matematik lærer.❓
2024-08-06 19;45;40,33 Redigeret
Citat fra: jyllands-posten 05/08/2024 KL. 21:00
37.000 unge er dårlige betalere: »Skolen har et ansvar«
Børne- og ungechef i Danske Bank vil have privatøkonomi på skoleskemaet, så færre unge ender i gæld, og flere får gode pengevaner. Men skoleleder mener ikke, at det er løsningen.
Det ville antagelig være en god ide at starte tidligt med at bruge regneark i Matematik timer, hvor man f.eks. også lære at styre en almindelig DankortRegnskab❓
Regneark er det program jeg bruger mest 😎
OpenOffice- & Libreoffice Calc er gratis programmer til Windows PC.
2024-08-13 20;26;07,48 Redigeret.
Citat fra: Jyllands Posten 12/08/2024 KL. 13:39
Rod i Forsvarsministeriets regnskab
Rykkere, inkassosager og manglende overblik over materiel. Rigsrevisionen kritiserer Forsvarsministeriet for ikke at leve op til statens krav for regnskabsforvaltning.
Måske burde Forsvarsministeriet installere nogle regneark i Forsvarsministeriets  computer❓❓❓
Citat fra: Børsen Fakta 02. jun. 2014 KL. 10.30
Fakta: Her er Løkkes bilags­sager
Måske kunne Løkke også have gavn af et Regneark på sin computer❓
Mere brugbar matematik tak❗❗❗😎
2024-08-23 19;52;27,39 Redigeret
Citat fra: JP 20/08/2024 KL. 13:33
Aarhus Kommune har regnet 1,6 mia. kr. forkert
Aarhus Kommune mangler 1,6 mia. kr. at bygge for frem mod 2034, viser et anlægseftersyn. Det udfordrer byrådets kommende budgetforhandlinger.
Citat fra: Google Play
Calculator MobiCalcMobi Calculator er en gratis, reklamefri Android-app til alle, der sætter pris på en god brugergrænseflade og funktionalitet.
Lommeregner til enkle og komplekse beregninger med procentkapacitet - Nyd annoncefri bekvemmelighed!
Den brugervenlige grænseflade gør det til en fornøjelse. Denne enkle, men funktionelle lommeregner er nyttig for skolebørn, studerende, professionelle på arbejdet og som go-to-lommeregner til hverdagens opgaver.
Citat fra: En Google-bruger 30. maj 2020
MobiCalc er den bedste regnemaskine i playbutik, har testet de 20 med den højeste score, den understøtter vertikal og horisontal view, fin brugerflade og gratis ( uden reklamer ) Nice job ,thanks a lot.
Jeg har installeret regnemaskinen på mine gamle Android 4 mobiltelefoner, som jeg kun bruger offline med forskellige værktøjsProgrammer.
Desuden kan man ændre [÷ og x] til [/ *] så man bruger samme taster på regenark og regnemaskine 😊
« Senest Redigeret: 23, August 2024 - 19:53 af jj- »
Sv: Talforståelse
« Svar #1 Dato: 22, Juni 2024 - 20:45 »
På et skakbræt med 64 felter lægges ét riskorn på første felt. På felt 2 dobles antallet til 2. På felt 3 dobles igen til 4. Felt 4 dobles til 8, osv…osv.
I felt nr. 64 vil der ligge 9.223.372.036.854.780.000 riskorn.
Sammenlagt vil der i alle 64 felter ligge: 18.446.744.073.709.600.000 Riskorn
(Atten-Trillioner, FireHundredeSeksogFyrre-Billiarder, SyvHundredeFireogFyrre-Billioner, TreogHalvfjers-Milliarder, SyvHundredeNi-Millioner, SeksHundredeTusinde  Riskorn)
Hvis 40 riskorn vejer 1 gram, vil mængden af ris veje: 461.168.601.842.740 Kg
(FireHundredeEnogTres-Billioner, EtHundredeOtteogTres-Milliarder, SeksHundredeEn-Millioner, OtteHundredeToogFyrreTusinde Ton SyvHundredeFyrre Kg )
Til kogte løse ris skal der bruges: 864.691.128.454.950 liter vand (4,5 dl / 240 gram ris)
(OtteHundredeFireogTres-Billioner, SeksHundredeEnogHalvfems-Milliarder, EtHundredeOtteogTyve-Millioner, FireHundredeFireogHalvtredsTusinde, NiHundredeHalvtreds liter)
(Det er fa…… en stor grydefuld)
Hvis gryden er firkantet og 1 Km på hver side, skal den være næsten 865 Km høj.
( HUSK AT RØRE I GRYDEN SÅ RISENE IKKE BRÆNDER PÅ)
