  • Total antal indlæg: 16013
  • Total antal emner: 1403
  • Flest online idag: 12
  • Flest på samme tid: 876
  • (10, December 2025 - 09:39)
Gæster: 9
I alt: 9
Forfatter Emne: Cities - The main cause of climate change  (Læst 12496 gange)
« Dato: 29, August 2024 - 20:16 »
Citat fra: 18 September 2019 UN News Climate and Environment
Cities around the world are the “main cause of climate change” but can also offer a part of the solution to reducing the harmful greenhouses gases that are causing global temperatures to rise according to UN-Habitat Executive Director Maimunah Mohd Sharif.
Why are cities an important part of tackling climate change?
How can cities contribute to reducing climate change?
Climate change is already happening and affecting cities, how can cities prepare for this new reality?
To what extent are the poorest and most vulnerable people most impacted by climate change in cities?
How different are the challenges faced by cities in developing countries compared to those in the developed world?
Citat fra: EU Science Hub
News article25 July 2022Joint Research Centre3 min read
Cities are often 10-15 °C hotter than their rural surroundings
2024-09-09 20;13;22,64 Redigeret
Citat fra: 2. august 2024. FN’s Klimapanel, IPC
IPCC, har netop holdt møde i Soa. Her satte man rammen for, hvad to nye rapporter
skal indeholde.
De to nye i klassen, ’Særrapport om klimaforandringer og byer’ samt ’Metoderapport om emissionsopgørelser for
kortvarige gasser og partikler’ skal stille skarpt på, hvordan byer kan blive mere klimavenlige og udpege de gasser, der
kommer efter CO2 , metan og lattergas, som også bidrager til drivhuseffekten.
Men alle de sorte fladers bidrag til varmeboblerne i byerne, blive antagelig ignoreret igen❓❓❓ 🙁
« Senest Redigeret: 09, September 2024 - 20:15 af jj- »
