  • Flest online idag: 67
Gæster: 31
I alt: 31
Forfatter Emne: Novo Nordisk  (Læst 20561 gange)
Novo Nordisk
« Dato: 17, November 2024 - 07:39 »
Citat fra: JP 15/11/2024 kl. 15:30
Trumps nye sundhedsminister hader Novo: »Vi bør overveje at genplante køkkenhaven, før vi sender flere penge til Danmark«
Den danske medicinalgigant Novo Nordisk tjener milliarder i USA bl.a. på salget af slankemedicin. Men Trumps sundhedsminister vil hellere give pengene til de amerikanske bønder.
Nogle få tynde skive rå agurker på toppen af en tynd lag mild ost på en skive rugbrød kan muligvis også give en hurtige mætheds fornemmelse og bidrage som et billigt slankemiddel❓
Søg evt.  med:
The Locust and the Bee
Predators and Creators
Redigeret  2024-11-22 20;05;10,92
Måske vil Elon Musk starte en kaktus farm på Mars❓
Og så sælge produkter lidt billiger end Novo's❓
Citat fra: Biomanantial
Published: 11/27/2011 - Updated: 09/25/2018
Author: K. Laura Garcés G
5 Comments
The cactus is a plant with many medicinal properties. Besides being a great source of fiber, calcium, antioxidants, minerals and vitamins, it contains elements that help both the intestine and blood to keep working in order and with good condition, plus it is one of the best natural remedies to treat and prevent diabetes and hypoglycemia, because the cactus increases insulin levels and sensitivity, which manages to balance the level of blood sugar, preventing the formation of bad fats that accumulate in the body, causing overweight and other health problems.
Citat fra:  HCM Magazine
Cactus obesity 'cure'
By
An African cactus plant is currently being tested by scientists in the race to find a wondercure to combat obesity. The hoodia plant, found across southern Africa is said to have appetite surpressant qualities and has been used for years by tribesmen in the Orange River region to surpress appetites on long hunting trips. British biotechnology company, Phytopharm, has patented the plant as P57 and will begin clinical trials in June. Marketing rights to the drug have been bought by Pfizerand and are valued at £9m a year.
« Senest Redigeret: 18, December 2024 - 20:02 af jj- »
Sv: Novo Nordisk
« Svar #1 Dato: 22, November 2024 - 13:45 »
Agurken tjener intet formål. Osten skal være en enkelt skive vellagret og  med kavt fedtindhold.
Sv: Novo Nordisk
« Svar #2 Dato: 23, November 2024 - 20:01 »
Citat fra: harbst
kavt❓❓❓❓❓
Citat fra: Nordjyske ord og vendinger
3. ’Kavt’. Dette ord kan helt og aldeles tilskrives det aalborgensiske vokabularium. Et ord som aalborggensere ynder at fremhæve med stolthed, når deres dialekt bliver kommenteret. Der er tale om et meget særligt tillægsord, der bruges om både situationer, personer eller handlinger, hvor noget er uforholdsmæssigt åndssvagt. Hvis noget virkelig er kavt, vil man i stedet for stemple det som værende ’åndekavt’.
Sv: Novo Nordisk
« Svar #3 Dato: 05, December 2024 - 13:42 »
Somme tider kan man ramme en tast forkert
Sv: Novo Nordisk
« Svar #4 Dato: 18, December 2024 - 20:04 »
Citat fra: harbst
Er det på skærmTastetur du somme tider kan man ramme en tast forkert❓
Heldigvis er skaden i dette tilfælde minimal😊
Det er antagelig værre, hvis en masse penge ende på det forkerte konto på grund af tastefejl❓❓❓🙁
Eller man bliver offer for bivirkninger ved brug af Ozempic❓
Citat fra: Ingeniøren
Ozempic øger risikoen for synstab: Nu reagerer Lægemiddelstyrelsen
Sv: Novo Nordisk
« Svar #5 Dato: 21, December 2024 - 16:19 »
JJ
Harpst har ofte slå fejl og det har han altid haft i den tid dette forum har eksisteret.  Jeg har kendt ham, fra før Ebbe startede  dette sted så bær over med det. Du er jo meget glad for at udtrykke dig her med alt mellem himmel og jord som sjældent har en kvalitet som Harbst!
For selv om der er stavefejl så fejler Harbst  indlæg teknisk ikke noget.
Som underviser af ingeniører siden 1961 kan jeg sige at ordblindhed er ret almindligt forekommende blandt ingeniører.
MVH Bjarke Mønnike
Sv: Novo Nordisk
« Svar #6 Dato: 05, Januar 2025 - 14:28 »
Jeg er besteemt ikke ordblind.
Hvis man skriver for hurtigt kan denne hjemmeside ikke altid følge med i teksten, eller der kan være små huller i datastrømmen til min internetforbindelse. Den går via en mobiltelefon.
Men jeg ved godt at jeg nogen gange laver slåfejl og rammer en nabotast. Hvis det er et vigtigt brev eller professionel rapport, læser jeg det godt igennem og retter.  Her har jeg dog værer for tilbøjelig til bare at sende med det samme.
Mønnikes indlæg er dog heller ikke helt uden fejl.
« Senest Redigeret: 09, Januar 2025 - 15:30 af harbst »
Sv: Novo Nordisk
« Svar #7 Dato: 26, Januar 2025 - 14:10 »
Der kan du se JJ, at jeg har ret  ;D
Vi levar alle fjel , men er det frøtse og det sitdse bagsotv i et ord det ritgige kan de satgnes lesæs.
Og ja Harbst, nabotaster og ordelinger er noget der en evig plage for alle ;D
